Hello all!
I am in the process of replacing my wood spars wings with the Milman aluminum spars. Presently working on the right wing first, all wing parts are cleaned, ribs straightened, holes drilled and deburred. Before primer I wanted the check the fit of the rib spar windows to the new spars for any clearance issues, the Milman main and rear spar caps measure .812" +/- .002" in width, the rib spar windows measure .805" +/- .005" in width for the main (front) spar and .800" in width for the rear spar. Will be a snug fit if I cannot do a little rework to open those up. The big issue: 3 of the ribs, p/n 5-274, located in the flap bay have a rear spar window width of only .770" +0.000"/-.002" definitly not going to let that aluminum spar cap through, was fine for the .755" wood spar width. Has anyone run into this issue. Maybe its an issue for that era of rib stampings?? would hate to order 6 new ribs from Univair and have the same results.
Todd Kendall
Todd Kendall
