1972 7GCBC
gregpwyatt
wyoming
Any suggestions on a probable cause for inop NAV lights? I have LED Nav lights. None of the NAV lights are working but the landing lights and strobe work fine. Checked circuit breaker and did a reset and still not working. Is there a power supply for NAV lights other than the battery like a strobe power supply? Thanks
There's no power supply for nav lights, other than said wire to the light. Most common issue is corroded or broken ground at the light.
All inop? Then I would start testing for voltage after CB and after switch from switch should be straight out to lights. Individual inop start with grounds.
