CaptCaveman
- Joined
- Apr 5, 2018
- Messages
- 13
Just bought a 96 Super Decathlon....While the plane has a lot of ramp appeal during the day light..>I am looking to upgrade the night time lighting...Nav,strobes,landing light. Any suggestions?
Landing Lights:
A buddy of mine put a "Hi-Lo Beam" LED from Larsen Lights on his plane. In aviation terms, they are dirt cheap - under $35 each! He absolutely raves about his "Hi-Lo" LED. Says it is much brighter than the old GE bulb, the "hi-beam" portion projects a lot better, and the "Lo-beam" part illuminates the taxi area far better. And when he bought his, they only had the 18W version available. Now they offer both 18W and 24W versions. The 24W one must be incredible!
On the Hi-Lo LEDs, there are three spades for wiring (2 positive and 1 negative), with the original idea that you would use a dual-position switch and wire one leg to the "hi" and one to the "lo" beams. But after consulting with Larsen, my friend who used these on a Rockwell Commander 114 (single landing light like the Citabria) used a "Y-jumper to connect the Hi and Lo posts together so that they both came on at the same time. Still well below the original bulb's wattage, and WOW it lights up the world! He used the "Owner maintenance" provision of the regs, and signed off the log entry as "Replaced PAR-36 landing light bulb with LED equivalent." When I do mine, that's what I'll use.
On that same page, Larsen also offer "Spot" (20º beam) and "Trapezoid" (60º "flat" beam) that roughly correspond to "Landing" (typically 10-15º beam) and "Taxi" (typically 40-60º beam) lights for your friends with both taxi and landing lights on their planes.
LED Position / Strobes:
The folks at uAvionics are just about to get their skyBeacon certified by the FAA. They are already shipping an "Experimental-only" version of this combination LED position light, ADS-B Out (UAT 978), and WAAS GPS position source that replaces the port-side position light, and fully meets the 2020 mandate for ADS/B, and sells for $1500.
An EAA friend of mine was a test customer for their experimental version, and he says it took (literally) less than 10 minutes to install and configure. You just remove the existing position light, connect the two position light wires to the SkyBeacon, then run the configuration app they provide via the App Store to tell is how long your wings are, what your transponder's ICAO code it, etc. Under 5 minutes, easy. No power supply other than the standard 12v wires for position lights. Turned on and off via the position light switch.
uAvionix are working on a "Certified" version of the SkyBeacon, expected to be available this year (cost around $2500-3000). They are in the final stages of the TSO / PMA process (expected 2Q18). This certified SkyBeacon will include everything the "Experimental" version has, plus a paired position light/ADS-B IN receiver in the right-wing. But the really cool thing is that both port and starboard units will also have certified LED strobe functionality!
That's pretty incredible to me: For under $3K (including installation) you could replace your position lights with LED, add wingtip strobe capability, AND meet the 2020 ADS/B mandate requirements, plus have a WAAS/GPS and ADS-B IN receiver for your handheld devices.
These uAvionix guys are newcomers to the GA scene, but they've been providing GPS and ADS-B to the military and drone markets all over the world, and are world-class technology leaders. They are the ones who created the "Scout" that ForeFlight now touts for low-cost ADS-B In capability. And, no, I'm not a stockholder, nor do I have any financial interest in these guys. (I wish!) I just got to see the experimental version at our last EAA meeting, and it was really cool to see how easy it was to add ADS/B by just swapping out the position light...
If I had not needed to replace my failing transponder anyway, I would have waited for this solution, instead of using the Appareo Stratus ESG to meet the mandate. I'm quite happy with the Appareo transponder, but the installed cost was a bit over $5K (my airplane's wiring was a mess).
Will this work in the original nav lights?
