I could never find out the difference between 7EC and 7ECA. That being said I had an O-200 powered Citabria that weighed 1045#. I don’t want the O-320 engine ones because they burn more fuel and I just want to putz around the area. Plus the big engine Citabrias have less useful load but need to carry more fuel thus less payload. I weigh 200# and want to carry another adult. I realize I will need to reduce fuel but would like to carry at least 25 gallons. I’m looking at one that weighs 1115# and was wondering if that’s about normal or might I find other 115 hp ones that weigh less?My 7ECA w/O-200 and Millman Spars is 1062 lbs.
are you saying the aluminum spars add weight? that's not necessarily true, it all depends on what's on the plane when you start and to what degree the builder packs on the paint and other changes in the process of doing the conversion. I lost weight doing mine, a few things were changed but the total weight represented a reduction when it was done.Without Milman you would be under 1000 pounds
I see. Champ vs. Citabria, I guess. ThanksThe difference, as near as I can tell, is the 7EC is an Aeronca, with rounded tail and wingtips. The ECA is a Citabria with squared off surfaces.
A 455# payload with max fuel would be outstanding. Much better than any other 7 ECA I’ve seen.
The ACA metal spar conversion brings with it the possibility of a 100# gross weight increase but I’ve heard that can be eaten up by an empty weight increase from the conversion itself. Is that true?
I’m aware of that. My question is does the factory, ACA, metal spar increase the empty weight of the aircraft therefore negating any or all of the 100# gross weight increase? I know the decision to go with the metal spar isn’t made to get the gross weight increase but it might be a factor.Milman spars don't allow for a gross weight increase, only the factory metal spar wings do that for you.
My O-235 7ECA has about 455 pounds of useful load remaining once full fuel and oil are onboard.
