One thing I like to do is learn how other people manage to kill themselves and destroy their aircraft, lest it happen to me. The NTSB Database is a great resource for that. Plug in your aircraft type, dump the data, and start reading.
Since I'm buying a Super D, I downloaded and skimmed all the accident reports for the 8KCAB. The raw data is posted here if you want to review, with links for each accident report.
Below is a summary of all reports where the aircraft was destroyed and/or someone was killed.
Some quick observations:
| Cause | Acro | Non-Acro | Total |
| Low Alt Maneuver | 23 | 6 | 29 |
| Unknown | 9 | 3 | 12 |
| Pilot Error | 3 | 8 | 11 |
| Engine | 0 | 8 | 8 |
| Structural | 2 | 0 | 2 |
| Mid Air Collision | 2 | 1 | 3 |
| Other Mechanical | 1 | 1 | 2 |
| Total | 40 | 27 | 67 |
- The single largest killer of Decathlon pilots is low level aerobatics. A few were airshow maneuvers, but most were simply someone initiating a spin at 1000 AGL and thinking they could recover, or trying a slow roll at 100 feet above the runway. Several more were low passes gone wrong. If you want to stay alive in your Decathlon, set a conservative minimum altitude and STAY ABOVE THE HARD DECK. I personally do not go below 3000 AGL during acro.
- There were numerous stall/spin accidents associated with engine out on takeoff or landing. The symmetrical airfoil of the Decathlon is probably a factor there. Keep the speed up if you lose your engine. It won't glide like a Citabria.
- There is only 1 documented instance of an unrecovered spin with otherwise sufficient altitude, and that was an inverted spin by an "instructor" with very little time in type. There are ZERO documented instances of unrecovered upright spins.
- There are only 2 documented instances of structural failure not due to pilot error. One was a strut attach fitting that failed. The other was a seat back that broke during pullout, causing the pilot to fall backwards and presumably over-G the aircraft. There are ZERO documented instances of spar failure, wood or metal, caused by the spar failing to withstand the rated load. One structural failure is counted in the Pilot Error category because the pilot initiated a Split S to exit a roll with a very high entry speed and full power.
- Pilot Error is a bit of a catchall for various flying or judgement mistakes: one flight into IMC, one flight into downdrafts in the mountains, a botched banner tow pickup, a few stall/spin accidents in the pattern, etc.
- Of the unknown causes, several more were probably low level aerobatics. It is likely that low altitude maneuver accounts for more than 50% of Decathlon deaths.
