I live in Spearfish South DakotaWhere do you live?
I have a core, but at last annual they found pitting on the front of the crankshaft, ?????
I did check the price, its a lot bigger than my wallet is. Thanks BBNot unusual for an aircraft that sat for a while at some point. Front of the crank is exposed outside the case, where condensation can collect on the bottom. Depending on depth, a good engine shop might be able to machine that out without red tagging the crank. If the crank is bad, that will run you about $7K just for the part, and that is IF you can find one. Some models are made of unobtanium right now.
Depending on the size of your wallet, might price a new exchange from Lycoming.
Either keep flying and closely monitor compression and oil analysis, or plan ahead and get it done on your terms.HmmmGood conversation I’m at a little over 1,600ttsn. Wondering what I do when I reach 2,000.
Just keep flying it! I think its terrible that people think a perfectly good running, healthy engine needs to be euthanized just because its reached some arbitrary number! There's so much more to the equation, and hours of operation has the LEAST effect (in my professional opinion of course) on the health and reliability of the engine. It further infuriates me that "professional" mechanics who should otherwise be experts in their field do the same. "older" engines almost never just catastrophically fail without warning.... they die a slow, agonizing (for the owner) death. a new, young engine is statistically far more likely to have a catastrophic failure.HmmmGood conversation I’m at a little over 1,600ttsn. Wondering what I do when I reach 2,000.
