chadmaisel
I have an 804-V sump fitting on my inverted system. It calls for christen part #50004-112 o-ring and #50042-020 gasket for the sump fitting. I've got an email out to ACA but does anyone else know where these might be had?
@chadmaisel What was the actual part numbers of the o-ring and crush washer? Did you get them from Aircraft Spruce?I have the vertical system - no plug no 10-32 rod. Just a sump fitting with O-ring and crush washer. I talked to my mechanic and found what I needed. Apparently the first part of the part number is not necessary. Who knew?
