Asking about sizing wires brought up a ratcheting crimping tool (by Hiperbiper maybe?). "Crimping" is the process by which a bare wire is locked into place within a terminal fitting by a mechanical crushing process.
These are the terminal ends, they are color coded by wire size
www.aircraftspruce.com
This is the crimping tool that was mentioned, ATS E300-002
www.aircraft-tool.com
And this is an excellent how-to video demonstrating how to do a good crimp.
Ring Tongue Nylon Insulated Pidg Terminals | Aircraft Spruce ®
Ring Tongue Nylon Insulated Pidg Terminals Each insulated PIDG terminal consists of a tin plated copper body, a tin plated copper wire support sleeve and a color-coded insulation sleeve.
TERMINAL CRIMPER (R/Y/B) from Aircraft Tool Supply
TERMINAL CRIMPER (R/Y/B) - Powerful full-ratcheting crimper with safety release and adjustable crimp pressure. Very comfortable rubber handles and ergonomic design makes it easy to install multiple terminals. Crimps Insulated Terminals & Splices: 22-10 AWG red, blue, and yellow.
