baggage door
Tangogawd
Alaska
I'm wanting to put a baggage door on the 7GCBC, anyone have pictures of Rainbow Ron's door, maybe compared to the factory door.
I can post pics of the framework from the factory. Is it possible though to cover over the door opening if it's there and you don't want a door?
back in a minute with pics
that looks real nice. might go that route. I want biggest door that will fit...... now, just what to do with that diagonal leg?!?!
Rainbow Ron’s, works good. Aca’s is better option and easier to sign off, I was done welding and didn’t want to weld the frame in.
747E1C14-FDA3-46DB-8E50-5199D5CBFC21.webpB4E45E00-788B-4659-B769-9B519BA049E7.webpII think the door opening is the same size. There is only so much space between the tubes. The door is helpful with small things but anything big still has to go over the seat. Extended baggage is the most useful addition. Battery is moved up to the firewall.
The Battery has already been moved to the firewall and extended baggage installed. I had a baggage door on my Scout, but is was smaller, custom built. Back before there was a factory option or otherwise
That is Rainbow Ron’s in the picture-hinged on the right. I also thought they were hinged different from the ACA welded.
