mamontb
I'd like to install in our 8KCAB a cable that runs from the battery solenoid to front of the rear seat frame so that we can connect a BatteryMINDER while the airplane is in the hangar. I purchased the interface kit. I was tempted to use an SAE O-ring connector, but aircraft parts must be used in a certified airplane. Has anyone installed this kit (or fabricated an interface) and can provide suggestions for routing? I want an easy access so that the BatteryMINDER can be plugged in by opening the cabin door (no baggage door, unfortunately). My notion is to avoid routing it under the baggage compartment carpet. I'm averse to running a cable underneath a carpet on which a load will occasionally be placed.
