It's reported that it's sometimes difficult to start I-O 320 when hot.
That's probably true, but with my 600+/- hours flying a 7KCAB, I've never had a difficult start.
That could be because I never needed to start when the temperature was above 90F.
However numerous times I've had to restart the plane on the ground when the engine was hot.
For example when refueling.
At least three times I've had the engine quit while doing spins.
The first time it quit, I was about 8,000ft AGL.
I pulled out of the spin and resumed level flight gliding.
Then I put the mixture full rich, the throttle to about half position, and put the plane in a very steep dive.
At 155 mph, the prop began to turn and the engine immediately started.
The engine was obviously hot.
In subsequent engine interruptions, I remembered that I had a starter, and just pushed the start button.
On each occasion the engine immediately started.
Now I always do counter clockwise spins, and increase the RPM from 800 (idle) to 1000 RPM.
This greatly reduces the likely hood of interrupted power.
I'm not an A&P, nor a CFI, so I very much welcome other's opinions and experiences.
