Citabria aBrakes
You will need a piston pump type oil can and a foot of 3/16" vinyl tubing. Purge all the air out of the tubing, connect it to the bleed fitting on the caliper, open the bleed fitting and pump hydraulic fluid until it comes out the overflow tube at the belly.
