Citabria Fuel Gauge/Float Replacement?
I heard there is a guy out there that will replace the cork float on a Citabria fuel gauge with a plastic one. Does anyone have any information for the person that does this?
Hi @Bartman!
We did clean the unit, changed the cork float to a plastic one and got a gasket. All from Spruce Canada (if I remeber correctly). We got a local glass shop to cut a new one. We had to get a few different thicknesses before we got it to fit right. Haven’t got a chance to put fuel in it yet though so not sure if it’s good! Lol! It wasn’t that big of a job.
Best of luck!
M-A
Hi @Bartman!
Best of luck!
M-A
Any chance you could look up the part number for the plastic float or post a pic please? Thanks :)
Hi @Bartman!
Here it is! From aircraft Spruce Canada.
Hope this helps!
Remember our story about the baffles inside the tank? While your at it, you may want to give them a good look over.
M-A
Thanks M-A! Did you have to remove the little crimp on the wire of the guage to get the old float off and to get the new one on? What did you replace that crimp with?
Bart :)
@Bartman
It’s been over a year but if I remember correctly, I just cut the old crimp and took the old one off, slipped the new one on and re-crimped it in the vice.
