Was inside the lower boot cowl cleaning and sanding the paint, figured I'd post a few pics in case anyone was wondering what's in there.
The gear legs bolt to the "gear truss" which is the structural member in the frame that carries most of the loads from landing. It is appropriately stout.
Inner gear mounting bolts, gear legs are separate from each other.
And a shot under the floorboards where the front pilot's feet would be. Master brake cylinders are visible (they lay on their sides parallel to the floor boards) as is the front of the controls torque tube that the control sticks pivot on (making roll action happen) and which connects the front and rear controls.
