A small collection of old and mismatched combination wrenches went to the hangar with me in case i needed one to grind to fit. Fortunately, I had an old Craftsman 9/16 box wrench that fit over the nut up top (12 point nut) and they both came loose using the wrench-on-the-end-of-a-wrench trick for extra torque. Had to cut two holes in the fabric to get lined up with the bolt heads and to be able to slide them out but once I had access, they both turned in place ok. we didn't remove the outer hardware, just loosened it, and leaving it in place gave a fulcrum to rock the gear leg up and down. With the nut in place flush at the top of the threads we used wood shims between the nut and the gear truss to work the bolt out by raising and lowering the outer end of the gear leg. lift the leg, insert more shims, push down, bolt moves out. one side was easier than the other and a pry bar with more wood shims made the difference.
we reused all of the hardware, it came out looking clean and went back in with a fresh coating of anti-seize.
