Cleco Rivet Gun?
I have this really neat Cleco model E3 rivet gun - bought it directly from Boeing. We figured it had built a whole bunch of B-17s, so I kinda got attached to it.
Then it failed - the trigger doesn't seem to be able to control it any more. Put air on it and it rivets whether you want it to or not.
I could probably replace it for cheap, but I would rather fix it. A neat kit of gaskets would be all it needs.
I found one of the gaskets a few years back - a teeny thing that looked like a gasket for a mixmaster kitchen thing - $35 plus a lot of shipping $.
So if any of you know of a niche outfit that fools with these ancient tools, let me know. Thanks.
Not sure what the difference is between an E3 and the E4 but here are some parts for the E4 if any are interchangeable.
All I need is that little plastic washer that sits between the valve and the body. I just made one out of a piece of inner tube, and will see if it works tomorrow. It is just a washer with a 5/16" hole. Not sure if the ridges on the original are critical.
Your link didn't show up?
Thanks! I went there, and the part I need is no longer available. So last night I made a punch, and punched one out of a truck inner tube. Guess what it worked! Hooray!
I had been trying too thick rubber, and it kept the trigger open.
