Citabria Complete 7ECA STC's list
Copied from https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgSTC.nsf/MainFrame?OpenFrameset
SA00024NY
Installation of Airwolf remote mounted engine oil filter kit AFC-K007 on single or multi-engine
Reissued
12/20/2017
SA00079NY
Installation of Airwolf remote mounted engine oil filter kit AFC-K008 on single and multi engine
Reissued
12/20/2017
SA00081NY
Installation of Iceman Aviation Supplies, Inc. Carburetor Ice Detector.
Reissued
06/09/2016
SA00087NY
Installation of Cu-Sonde Meteorological Measurement/system models CS-1A or CS-1B; and installation
Reissued and Amended
08/22/1995
SA00191AT
Installation of carbon steel brake discs that have melonite surface treatment.
Reissued
11/14/1994
SA00212BO
Installation of Lycoming O-320-A2B engine and Sensenich 74DM6S8-1-52 propeller limited to 7ECA,
Issued
03/09/2005
SA00215NY
Installation of CAVU Model AM100 AVMIX engine fuel/air mixture setting system.
Amended
08/14/1995
SA00232SE
Installation of vortex generators on the wings and tail surfaces.
Amended
04/12/2005
SA00344BO Page 1
Installation of Parmetheus Plus LED PAR36 and PAR46 taxi and landing lights.
Amended
08/11/2016
SA00382BO (page 1)
Installation of Globalstar Antenna and Cradle provisions to support a Globalstar GPS-1700 in
Issued
04/10/2017
SA00402SE
Installation of a remote spin-on oil filter adapter. (GC-1B w/Lycoming or Cont 360 engine
Amended
01/23/2007
SA00432SE (PG 4)
Installation of EGT 701 series fuel flow instrument.
Amended
04/12/2013
SA00478CH
Installation of Cooper Superflite 102 Fabric.
Amended
06/04/2015
SA00780SE (PAGE 3)
Installation of the True Lock Safety Retention Axle Lock Nut System
Amended
06/28/2016
SA00795SE
Installation of vortex generators on the wings and tail surfaces of the above model aircraft in
Amended
07/19/2001
SA00823SE
Fabrication and Installation of Rainbow Flying Service front and rear wing spars and modified
Amended
08/08/2006
SA00860SE
Installation of Rainbow Flying Service fuselage formers.
Amended
08/11/2015
SA00861SE
Installation of J.P. Instruments (JPI) fuel flow indicating system
Amended
04/12/2013
SA01015SE
Installation of eligible Alaska Tire and Rubber Company TSO-C62d
Tires as listed in AML SA01015SE
Reissued
03/13/2014
SA01026SE (PAGE 1)
Improved fuel gascolator assembly.
Amended
12/19/2012
CONTINUED IN NEXT POST
SA01089SE
Improved replacement floor boards.
Amended
08/11/2015
SA01157LA
Installation of Electronics International Model FP-5 or FP-5L fuel flow/fuel pressure instrument as
Reissued
01/20/2005
SA01158WI
Installation of Aero Enhancements UV250-1 Supplemental Instrument Panel Lightning System.
Amended
03/29/2005
SA01233SE
Manufacture and installation of Alaskan Bushwheel tail wheel and fork assembly
Reissued
03/13/2014
SA01435SE
Installation of J.P. Instruments (JPI) Primary Engine Data Management System
Amended
01/22/2018
SA01669CH
Installation of Challenger Reusable Air Filter
Amended
09/03/2014
SA01750CH
Installation of Swing Type Engine Mount per Air-Energy Service, Inc. installation instructions AESI
Reissued
10/23/2004
SA01765SE
Installation of Alaskan Bushwheel TSO-C26d wheels, Part Number (P/N) ABI-1010
Reissued
03/13/2014
SA01768SE
Installation of an oil cooler system.
Amended
05/18/2015
SA01818WI
Installation of Garmin G5 Electronic Flight Instrument
Amended
10/18/2017
SA01944CH (1 OF 2)
Modify airplane to fly on unleaded automotive gasoline, 87 minimum antiknock index, per ASTM
Issued
03/05/2004
SA01988SE (PAGE 1)
Installation of Electronics International Inc. Glass Panel Engine Monitor (with In-Flight Data)
Issued
04/17/2009
SA02033AT (PAGE 1)
Modification to install an air-oil separator to prevent oil from being aspirated from the engine
Amended
07/25/2008
SA02110CH (PAGE 1)
Installation of a Time Trac Data Recorder
Reissued
01/11/2010
SA02153LA-D Page 2
Installation of Garmin G600 Primary Flight Display (PFD) and Multifunction Display (MFD) System
Amended
11/17/2016
SA02212AK (PG 1)
Replacement of existing landing and/or taxi light reflector and bulbs with high intensity discharge
Amended
10/30/2017
SA02268CH (PAGE 1)
Installation of Airwolf Filter Corp. Air Oil Separator
Reissued
12/20/2017
SA02283SE Page 1
Installation of Electronics International Inc. Glass Panel Engine Monitor (with In Flight Data)
Amended
06/30/2014
SA02283SE Page 2
Amended
06/30/2014
SA02295SE
Installation of an alternate method of fastening aluminum wing ribs to wood spars
Issued
04/25/2014
SA02402SE Page 1
Issued
06/24/2014
SA02428AK
Installation of a hydraulically actuated ski drag assembly
Issued
05/02/2014
SA02428SE (Page 1)
Installation of an Air Stream Switch for an electric time recording device on non-pressurized
Amended
03/09/2017
SA02442AK Page 1
Approval of the L-3 Communications NGT 2000/2500 ADS-B system
Issued
01/28/2015
SA02444AK (Page 1)
Approval of the L-3 Communications NGT 9000/9000R ADS-B system installed
Amended
02/24/2017
SA02476AK
Installation of the Airglas, Inc. LC18-ACA Cargo Pod
Issued
11/15/2016
SA02511SE
Installation of replacement fuel quantity indicator sending unit(s)
Amended
04/19/2018
SA02520AT
Installation of M-20 Oil Separator, model 600-WP.
Issued
05/30/2002
SA02566CH
Installation of the Custom Fiberglass Molding, Inc. (CFMI) Model 1500, 2250-001, or 2250-002
Reissued
12/05/2015
SA02825NY Page 1
Installation of Aerospace Logic Aircraft Instruments
Amended
10/10/2012
SA02979CH
Installation of the Lycoming O-320-A2B engine in accordance with H. O. Aircraft, Inc. Installation
Issued
07/01/2011
SA02987CH
Installation of the Electroair Electronic Ignition System
Amended
07/12/2016
SA04032CH
Install rocker switch assemblies
Issued
10/08/2015
SA04046CH Page 1
Installation of L-3 GENESIS ™ Electronic Standby Instrument System (ESI-500/MAG-500)
Reissued
05/11/2017
SA09470SC
Installation of Starter Indicator light system.
Issued
06/18/2001
SA10126SC (1 OF 2)
Installation of Aero Advantage ADV200 series vacuum pump per Aero Advantage Drawing Number ADVMSI
Amended
10/23/2003
SA105NW
Mounting and wiring for occasional installation and use of Barnes Engineering Company airborne fire
Issued
04/30/1974
SA10822SC
Installation of EFD1000 Primary Flight Display
Reissued
07/17/2015
SA10921SC
Installation of an alternator and regulator as a replacement to existing OEM generators and
Reissued
07/17/2014
SA11137SC
Installation of Plane-Power ALT-FLX alternator
Reissued
07/17/2014
SA11174SC Page 1
Installation of BendixKing by Honeywell KSN 770 and KSN 765 WAAS LPV approach capable nav/comm
Amended
03/24/2015
SA1315WE
Installation of Mixture Monitor (exhaust gas temperature probe, gage and selector) in accordance
Reissued
04/15/2011
SA1351WE (PG 1)
Replace existing fabric on wings, fuselage, empennage, and/or control surfaces, with Ceconite101
Amended
08/19/1983
SA1358GL
Install Model R2800 retractable skis.
Issued
03/07/1989
SA1417GL
Issued
10/12/1989
SA1504GL
Surrendered and incorporated into STC SA241CH.
Surrendered
06/14/2002
SA1512WE (1 OF 2)
Installation of exhaust gas temperature monitoring systems Model EGT-1.
Amended
02/22/2007
SA1536WE
Installation of larger rudder.
Reissued
06/05/1969
SA1562GL
Install Lycoming engine model O-320-A2B and Sensenich propeller 74DM6S8-1-56 and other associated
Issued
03/28/1991
SA1626NM Page 1
Installation of Electronics Int'l Digital EGT/CHT Instruments and accessories. (201 Series)
Amended
03/09/1993
SA1735GL
Installation of Master Nag warning system.
Amended
03/21/1994
SA1768GL
Install Aero Fabricators shoulder harness and seat belt assembly.
Issued
07/01/1992
SA1912NM
Installation of Schneider wheel skis, 6-inch x 10-inch aluminum wheel adapters and 29x11.0-10 8-ply
Issued
12/25/1983
SA191NE
Replace original brake discs with discs modified in accordance with Roland Longarzo procedure.
Reissued
10/04/1984
SA1970CE
Operation of airplanes on unleaded automotive gasoline
Amended
03/05/2012
SA2-934
Installation of fiberglass covering
Reissued
09/10/1996
SA2190NM Page 1
Installation of electronics International Digital Volt/Amp Gauges and Accessories.
Issued
02/16/1984
SA220SO
Tow bar, release mechanism, and safety tow link.
Amended
11/08/2017
SA2309WE
Installation of Madras Air Service Part No. 104 wing tips.
Amended
02/05/2016
SA2335SO
Installation of Appalachian Accessories P/N 73-5 brake discs.
Reissued
09/29/1995
SA2350NM Page 1
Installation of Electronics International Inc digital carburetor/outside air temperature gauges
Amended
06/06/1990
SA241CH
Install Ceconite 101 fabric.
Amended
07/11/2006
SA2557NM (1 OF 2)
Installation of KS Avionics EGT/CHT-2( ) combined exhaust gas and cylinder head temperature
Amended
02/22/2007
SA261AL
Installation of Airglas Model L2000 and L-1650 wheel replacement skis.
Reissued
08/14/2012
SA2683NM
Installation of Precise Flight, Inc. stand-by vacuum system (SVS)
Amended
03/10/2005
SA2687NM (PAGE 1)
Installation of Truboplus/ Electronics Int'l gauges and switches.
Amended
10/25/2000
SA2693NM (PAGE 1)
Installation of Electronics International digital volt/amp gauges and accessories.
Amended
12/10/2009
SA2699CE
Installation of aileron spades.
Amended
09/19/1991
SA2844CE (1 OF 2)
Installation of a plastic cap enclosure over the anti-collision strobe light system.
Issued
07/29/1992
SA3-424
Installation of Wiparie Skis Model CTF-2200 (Acft Skis) (FluiDyne) (Federal) tail ski on airplanes
Reissued
02/16/1993
SA3019WE
Installation of 8.50 x 6.00 4-ply rated, Type III aircraft tires.
Issued
04/30/1975
SA308EA (1 OF 2)
Installation of carburetor ice detection system 105AP in single and twin engine aircraft and single
Amended
11/20/1978
SA312CH
Installation of shoulder harness and crotch straps.
Issued
03/23/1995
SA334CE
Installation of Pee-Kay Model 1800 or B1800 (TSO-C27-2) seaplane floats and two auxiliary fins.
Reissued
12/23/1980
SA33CE
If Champion Part Number 7-480 door is installed, remove two of AN 380-2-2 cotter pins and two of AN
Reissued
03/06/2013
SA3531NM
Installing copper electrical cables. (182 S/N 33000 THRU 33842) (8E 833 and UP)
Amended
06/03/2014
SA356CH
Installation of seaplane safety covers.
Issued
05/22/1995
SA3618NM
Application of polyurethane finishing system.
Issued
07/15/1987
SA3829NM
Installation and Manufacturing of Aluminum Wing Spars
Amended
04/17/2017
SA3862NM Page 1
Installation of Electronics International Primary TIT/EGT/CHT instruments, remote switches and
Amended
04/25/1988
SA4-1210
Installation of Eonnex cover on aircraft surfaces.
Reissued
08/19/1980
SA4005NM (Page 1)
Precise Flight Inc. Pulselite Control System
Amended
12/18/2007
SA4172NM
Installation of Aviation Development oil filter.
Amended
05/22/2009
SA4302NM (PAGE 1)
Installation of Electronics Int'l digital automatic engine analyzer.
Amended
10/13/1989
SA4305WE
Installation of GAR-AERO wheel adapters and tundra type tires on the main landing gear
Reissued
01/14/2015
SA4375WP
Installation of saddle blocks as replacement for landing gear attachment U-bolts (P/N 1-9805).
Issued
10/29/1981
SA442AL
Installation of 8.50x6 4- or 6-ply rated Goodyear or UniRoyal tires.
Amended
11/07/1973
SA4503NM (Page 2)
Install Ceconite covering material.
Reissued
02/25/2011
SA4624NM
Installation of F. Atlee Dodge springs 2097 and 2127 to replace bungee cords on ski equipped
Issued
02/21/1990
SA4760NM
Replace wing rib PK screws with Marson Klick fast rivets (pop rivets).
Amended
02/22/1996
SA483AL
Installation of McCauley 1B90-LCM-7534 propeller.
Reissued
01/31/2008
SA4896NM
Installation of modified front folding seats.
Issued
08/09/1990
SA489EA
Installation of ARP Inc. carburetor ice detection system
Amended
12/05/2002
SA5156NM
Fabrication and installation of Pulsar-MOSFET Landing Light Flasher System
Amended
05/22/2012
SA531CH
Installation of Mitchell oil pressure gauge and oil temperature gauge.
Issued
07/16/1996
SA5656NM (PAGE 1)
Installation of burglar alarm system.
Reissued
07/21/1993
SA5656NM
Reissued
07/21/1993
SA5739NM
Installation of aluminum flange extension angles for attaching ribs to BHM metal spars.
Issued
07/10/1992
SA5755NM
Installation of a propeller anti theft device.
Issued
08/05/1992
SA5924NM
Installation of RPM instrument.
Amended
11/24/1997
SA5925NM
Installation of oil pressure/temperature instrument.
Amended
12/08/1997
SA5925NM
Amended
12/08/1997
SA5926NM
Installation of manifold pressure instrument.
Amended
08/15/1993
SA593CH (Page 1)
Install Champion SlickSTART magneto booster system.
Reissued
02/10/2009
SA608AL
Install leading edge cuff. (7KCAB land only)
Amended
08/31/1977
SA615EA (PAGE 2)
Installation of Whelen Anti-Collision Strobe Light Systems, Part Number 01-0770006-( ),
Reissued
05/02/2018
SA639NW
Installation of a Lycoming O-320-A2D engine, Sessenich 74DM6S8-1-56 propeller, and larger
Reissued
11/08/1978
SA693CE
Replace existing engine induction air filter with AC Spark Plug filter.
Reissued
06/20/2000
SA71GL
Installation of air filters
Reissued
06/20/2000
SA726AL
Installation of Northland Aviation main landing gear 'U' clamps.
Issued
04/16/1982
SA728AL
Installation of Schneider Model SWS-4000 main wheel skis and Schneider Model SWS-1000 tail wheel
Issued
06/25/1982
SA732GL
Superseded by STC SA01944CH. Modify airplane to fly on unleaded automotive gasoline, 87 minimum
Surrendered
03/05/2004
SA73CH
Installation of Wing Strut Fittings, P/N SAR 2-893 or SAR 2-893-1, and stiffeners, P/N 2-5009, in
Reissued
04/22/2005
SA745EA
Installation of Edo Model 88-88-1650A floats.
Reissued
09/17/1982
SA753GL
Incorporated into STC SA00478CH.
Surrendered
06/14/2002
SA754CE
Install Aero Model M1500, M1800 or M2000 main skis. (7GCAA w/oleo)
Reissued
02/12/2004
SA755CE
Install Model M1500, M1800, or M2000 main skis. (7GCBC w/landing gear)
Reissued
02/13/2004
SA800EA
Installation of Whelen Anti-Collision, Position, or Anti-Collision/Position Light System, and
Reissued
04/02/2018
SA8075SW (PAGE 1)
Installation of fiberglass covering. (M-62 SERIES PT-19) (G-73 SCHWEIZER)
Reissued
11/10/2003
SA8431SW
Installation of R15VON alternator control unit.
A gold mine for finding out what has been approved. I just used the one for my 8.50x6 4 ply tires.
It should be noted that some of those STCs are for a single serial number only (specifically some of the Lycoming O-320-A2B installations on 7ECA planes).
Good point. :)
Bet that engine is now on the type cert.
That comes up a lot, doing the engine upgrade via an STC or via the TCDS and sourcing everything yourself, both ways can be done legally.
It is, and is what they install on the whatever-the-7GCAA is called now (Sorry, I'm better with the secret decoder ring than with names).
It caught my eye because my plane is one of the one time STC planes with that engine.
I have to admit I have spent some time looking at float STCs.
So you're saying they published an STC but the STC only authorizes one airframe (serial number) to be modified that way?
Haven't looked at this particular STC, but there are definitely "one-time" STCs that are issued for (and valid on) only a single serial-numbered aircraft. They may publish them to make it easier for someone to reference that STC in pursuing their own "one-time" STC. Not sure about today, but it used to be MUCH easier to get a "one-time" STC than to get a "repeatable" one... Took a lot more documentation and testing with FAA oversight (Read $$$$) to get a repeatable one...
I also bought a set of 8.50 Aero Classics for my 7KCAB and test fit them on my cleveland wheels. The brakes are rubbing the tire side lightly. Wondering if you ran into this?
Saw you checked out float STC, I have a Clipper on floats if you want that ASES rating added ;)
JohnView attachment 1134
No issues with tires rubbing the brakes in my application. Running them at 12psi and super happy with them
I may have just over inflated the tire, they have 18psi right now. Will set at 12psi and check before I put the 6.00's back on for students to abuse. Would appreciate seeing the description portion of the 337 your IA approved for the STC. I assume you used the Guardian Flying service STC that all proprietary rights had been surrendered. Appreciate your advise and look forward to putting them to use
