While in annual ('75 8KCAB) my mechanic advised that the lower engine cowl fastener holes are *way* worn. These are the holes that attach the cowl at the firewall. He suggested either replacement, or repair. Repair (material/labor - mostly labor) was going to come close to replacement. He asked if I'd like to take a whack at repairing it myself. Why not? I have some, although limited fiberglass experience (marine).
The plan is to grind/abrade a 2" area along the firewall edge of the cowl, and lay in a 2" strip of new cloth using epoxy. I haven't worked out how to go about filling the mounting holes. I need to enlarge the holes a bit, for new material adhesion, since grease and oil has made its way into the raw edges of the holes. At present, I'm thinking using West System 404 high density filler. That stuff sets rock-hard.
Wondering how others have tackled this situation. Thanks.
