Firewall Odysee battery mount STC
Skymarc
Canada
I there an STC to install a Firewall Odysee battery on the firewall of a Scout?
I bought the front battery mount kit from ACA but I dont have the welded bracket inside the firewall and its a big job to remove the engine, remove the firewall to weld that extra bracket on the inside to confirm to the TC. Not something I want to tackle unless it was during an engine change but its not in the works with 480 TT .
From my 2006 model the factory was pretty sure I had the bracket welded needed.
I know cubs and cessna have these STC to install these with a simple bolt on application, anything for the Scout?
You might want to call Odyssey to see if they have an STC in the works or if they know of someone that is working on it.
