Anyone have a material source for the CF board? I'm about to replace mine, looking at birch ply.
You could look at Dragon Plate, just be aware that they're $$$.
You could also make your own plate. It's pretty easy if you can relax a little on the specs. It'll be a teensy bit heavier than from Dragon Plate, but much, much cheaper. If you take two sheets of glass and use vacuum bagging techniques, you can make a pretty decent "press".
How much weight is saved with the composite floor boards over the plywood? I work for an aerospace company and I am thinking of making some floorboards for my 7KCAB.
I am thinking of 6-8 plus of Toray 700 12k prepreg carbon. I am uncertain of the need for core "divinely, or Rhoacell)
The factory composite floors look fantastic.
What I fabricate for my airplane will be 100% carbon fiber, through and through.
