Can the fuel shutoff valve be repaired, or should it be replaced? Anyone have a part number?
Mine is creaky and hard to turn. No exterior leaks. However, I suspect it might be leaking internally and not fully shutting off. If I close the valve and drain the gascolator, a few minutes later there will be fuel in the gascolator again.
