My 2001 ACA tank has a leak where the drain boss was welded to the tank. I think it was a bad weld. A few years ago when it first started leaking I called Jerry jr at ACA. He mentioned unskinning the whole wing, removing the gas tank, welding it, and recover/paint. He said the charge would be $7500, which is about what I paid for the wing. I was so disheartened, I just let it sit in the hangar.
Can the wing be unskinned a few ribs in, exposing the tank, then weld the tank boss in place in the wing? Pressure test it at ? PSI. Recover the wing where the skin was removed, and match the paint somehow. The paint is the 2001 Dupont automotive paint they used, and has stripes.
She's flying again, but only on one wing tank (and only turning one direction). Just to knock the rust off the cam.
