How I did my 7AC is documented in the Restoration section of this forum. Pic start in post #38
Basically the plexi is drilled and countersunk for #8 wood screws and #8 countersunk washers. Locate and drill mounting holes. The rear edge is held in with #8 countersunk machine screws, washers and lock nuts. Dope the wood screws with yellow carpenters wood glue (titebond) prior to final installation to seal the holes in the wood. While covering you'll cover the mounting screws with facric to make it all weatherproof.
