Bummer, but 1800 should be adequate for most purposes with a little planning. Could be worse. See Johan Whiteman's thread. His 1970 GCBC has MGW of 1650#. With empty weight of 1230 it is basically a one person aircraft, or an adult and child.
Nobody will say it in public, but part of the art of flying these airplanes is developing some judgement on when over gross is acceptable. Most of this series aircraft climb well, so takeoff performance is not usually a constraint. My Super D, which is the heaviest variant with the least effective wing, is off the ground in 1000 feet and passing thru 500 AGL at the end of our 4000 foot runway at best ROC and MGW. Flat bottom wings climb better, even with a smaller engine.
Likewise for CG and in-flight characteristics. Almost impossible to exceed rearward CG limit with pilots and fuel. With a lot of baggage you could do it, but you usually run out of space first. I had the baggage area of my Decathlon piled to the roof with camping gear for Oshkosh, and was nowhere near my weight or CG limits.
That leaves landing, which is where the risk comes in. The original steel landing gear were adequate for the original aircraft, but as the series progressed into bigger engines, they were not upgraded in the design. That left the gear a little flimsy for the heavier aircraft, and thus vulnerable to prop strikes and nose overs from excessive gear flexion, especially with older gear legs that have been "sprung". I believe the MGW on many of our aircraft is driven by drop test results during type certification. ACA finally rectified that issue with the heavier aluminum gear and replacement of the U bolts with bar bolts about 20 years ago. That is why the metal winged Decathlon must have aluminum gear to get the 1950 MGW.
So ... IMO only ... if you are not operating from a short field, a prudent pilot who knows his plane well might reason that taking off on an XC trip 20-30 pounds over gross is an acceptable risk when you know you will be well under gross when it comes time to land.
Acro is a whole different ball game. There is engineering and advanced math involved there. Those limits should be carefully respected, especially if you are pulling towards the limits of the aircraft, such as my avatar illustrates.
As Bob would say: Opinion.
