Hangar Equipment Necessities
As is often the case, when I'm out doing something aviation related and I have questions, I think of all y'all. So, being new to the hangar scene, I'm wondering what you would consider essential equipment for a hangar.
Besides a step ladder, shop vac, a small compressor for filling tires and blowing tight spaces clean, mousetraps..........what's essential?
Considering you are creating airplanes - a drill press, lathe, welding equipment, combo wrenches and screwdrivers hanging from all three walls, saw horses, lots of bench surface area, and a really good wing rack.
Now if I could just clean up and organize once in a while . . .
I have my big (old) air compressor at my hangar but I don't use it on the plane. I imagined using it for compression checks, which I'm sure will happen when I'm the head wrench turner on my Kitfox. For tires I use an old bicycle pump, and I have two low pressure tire gauges which read low enough I can nail 12psi easily.
As above, a set of combination wrenches and good quality screw drivers hang on my wall. A broom and dust pan get used often. It's crazy how much dirt shows up on the floor of a hangar or garage with the doors closed and no activity.
I have one of those quartz shop lights on a stand, and from it I have an old school drop light. That contraption comes in handy very often and doubles as a source of warmth. I also have a couple of good flashlights and a headlamp. Inspection mirror and magnetic picker upper things are both handy no matter what you're working on.
Microfiber cloths and Lemon Pledge (or suitable high tech replacement) are always needed.
I have a big white board on the wall with a table of numbers showing aircraft TT, engine SMOH, next annual, next oil change, transponder and ELT. It also shows my own currency for BFR, CFI, medical and 90 day tail wheel currency.
I didn't run a dispatch log until I took on my non-equity partner but with both of us flying it was required to keep track of the hours he was flying off.
The white board also serves as a scratch pad where we make notes to each other about fuel or an added quart of oil. I also have a running total of hours per added quart (seems to vary around 10-15 hours/quart).
Now I've got a ton more crap in my hangar but that is my list of essentials. Oh and a comfy chair or two.
I haven't gotten around to that yet but I know I want to pick up a third row seat like we have in our old Suburban and put it on wheels so it can be rolled out for sunset runway viewing in the summer. perfect beer and cigars with a buddy seat.
Been building out my tool collection but don't have the mirror and magnetic grabber yet. Put together a new drill set and bought a new cordless drill for the hangar this evening. For tools I've been trying to find good used American made pro grade tools on facebook marketplace and Craigslist but there are so many things that I don't know I need until I need them and when that happens I'm done for the day so I can go find the right tool.
The big white board is a great idea, especially for keeping continuity between work sessions and for keeping things from slipping through the cracks. Will have to see what's available in the local used market.
Thanks for the suggestions, anyone else?
My whiteboard is 4x8 feet, and I did get it by watching craigslist for a deal. They are quite expensive otherwise. I tried to make my own with the rattle can white board paint but it was only slightly more erasable than flat latex.
Refrigerator. Fan(s). Tools; start with the basics, buy special or specific stuff as the project dictates. Cabinets or boxes for hardware. Fire Extinguisher. GOOD First Aid Kit.
A copy of AC43.13 (you'll be surprised at the info in there..).
I mentioned having a fridge when I signed my rental agreement and they weren't supportive. It seems that I'm ok with lights and minor other uses but if I go nuts with a compressor or fridge they're going to come looking for me to pay my share of the electric bill. At some point I'm going to need a paint booth but until that time I'm just going to lay low and have to use a cooler in the summer. :)
The first-aid kit idea is a good one and I was thinking I should have some water bottles on hand as an eye wash station. Need to buy a fire extinguisher, should have had it there the first day. :rolleyes:
A guy near Philly has a stack of 4x8 white boards, new, for like $80 I think but my frickin' suburban is in the shop so there's no way to go pick one up. :mad:
You can get 4x6 rollup whiteboards from Amazon for around $50 and stick them on a sheet of plywood.
Music! Life is nothing without music so I have to agree with you. My ancient CD/AM/FM radio mini boom box is holding up ok for now but it would be better if I could bluetooth my phone to a speaker or two and just play my library or something from Spotify.
Got a fire extinguisher this past week and finally hooked up the propane heater that my IA friend donated. It sounds like you're working under the APU exhaust of an EMB-120 but it's heat and it's that or nothing is getting done. Radio is useless with the heat going so this post just went full circle. :)
And welcome @Low Lead ! WHen does the pup solo?
