Yes. Item 111(d) is a Delco Remy starter, so your aircraft is approved with a starter-equipped O-200. If it was in all cases a pull-type starter, your push switch is indeed an alteration. However, there is no stretch of the imagination that can make a push to start switch a major alteration. Log book entry.
In the olden days an inspector would have been obliged to turn you down if you submitted a 337. Now you can submit anything you want on a 337, and the only person that would care is a knowledgable mechanic. The FAA doesn't check them.
I see major alterations all the time where the IA approves the data. Cannot do that.
