ehaecker
Greetings all,
For you 7KCAB/8KCAB operators... My 7KCAB HATES hot starts and running at low power following a flight. Say, if I get fuel after a flight then start up to taxi to my hangar, it will start pretty easily, but it runs like absolute CRAP. It will sometimes give me a false start and quit a few seconds after starting...once I get it running, it will occasionally "miss" in a rhythmic fashion, burble and pop like an old radial. Am I the only one with this issue with an injected 320? Is there some sort of purging procedure that has proven successful to purge the vapor out of the lines? Once I increase power above about 1500 RPM, it smooths right out.
My friend with a PA-30 said his IO-320's did the same thing. Just wondering if there's a way to smooth it out a bit.
