In my determination to completely overanalyze my engine monitor decision, I am taking another look at the JPI EDM-730. Starting to think it is the best fit for my needs and wants.
Initially I was turned off by the lack of primary capability. The 730 is STC for secondary only, meaning you have to leave all your old instruments and gauges in.
But, am starting to realize the flip side of that is flexibility. With the 730, you can buy the base model for $1550, which gets you EGT/CHT. Then in the future you can add whatever additional sensors you want, all the way up to the full 830 setup. The display automatically configures to the new inputs, so no sending it back to the factory.
So, I don't have to spring for $4K for a full monitor now. But later on, I can add fuel flow, oil temp, and oil press for a few hundred bucks each.
My steam gauges work fine for oil T and P. However, I confess I don't monitor those as closely in flight as I should, like most pilots I suspect. The idea of having an alarm to alert me to problems is appealing.
I don't really see the need for MP and RPM. My tach is new and works fine, and steam MP gauges are easy to replace and cheap to overhaul.
The only big negative is that I would need to rewire my switch panel to add an avionics master. As we have all observed, access to that area is a PITA
