All,
This site has been so helpful to me as a new Super Decathlon owner, I am so appreciative. I have another question that might seem a bit silly but wanted to throw it out there anyway.
The 2005 Super D I purchased a couple of months ago came with a seemingly older POH with a gross max weight of 1800 lbs. When I asked the seller he said that's what he had always used as well. However, when I called ACA and spoke with one of the nice sales guys there he said in 2005 they were making the aircraft with both the aluminum and steel landing gear. I can't remember which but I believe he said the aluminum has a 1950 lbs gross max weight and raises the plane up a bit higher from the ground while the steel is the 1800 lbs gross max. He mentioned that on the struts that have the lower max weight, you can see the break fluid lines running down them. This makes me believe that I have the aluminum(?) struts which would have a gross max weight of 1950 but I am just unsure. Here is the POH I received with the plane and a few photos of the struts and plane. Just trying to figure this out as a 150 lbs difference is quite large and would be good to know.
Merry Christmas everyone!
