Old TC specification was left wing root. New TC specification is front panel. So IMO either can be legal if properly documented.
Obviously it is legal if it came from the factory that way. So start by finding out what year the specification changed. I think this was fairly recently, within last 10 years or so, when they went to glass panels. Maybe someone on here knows the answer. If not, a call to Dale or Chad at ACA will answer that.
If your aircraft is older, then it was updated from the old to the new specification. If so, there should be appropriate documentation in the logs. Updating from old to new specs could be minor or major, depending on the work performed, as determined by the person who did the work.
Plenty of people have done this conversion, so it should not be too controversial. Mostly a paperwork drill. If lacking paperwork, it is not a deal breaker, just a negotiating point. Your IA might be able to do a condition inspection and make the appropriate entries. Worst case, remove and reinstall. For either option, first step would be calling ACA and obtaining the new drawing.
