Eric Brown
I have a 7AC with a newly overhauled O-200. Have a low oil pressure problem. Start up oil pressure is 50psi. When oil temp reaches 190, pressure is 20 psi at 2400 RPM. Idle pressure is 8 psi. Have reviewed Harry Fentons small Continental engines web page. The 5 items he recommends have all been done. No luck. To me, it seems that there is fixed open orifice in the engine that leaks hot oil. The oil pressure relief valve has been lapped and a new spring installed. Adding washers to the relief valve spring will increase the start up pressure, but when hot, it still returns to 20psi. Of the 8 small Continentals that I have overhauled, I've never had this type of problem. Anyone out there had a similar experience and know of a fix ?
