Rick
I posted a question on Facebook about a magneto problem and got some interesting replies one more than the others I think may be my problem, but thought I’d post here also. Flying from Oregon to Florida I stopped at an airfield outside Palm Springs for fuel. KMMC was reporting 112°, so I’m sure the ramp was hotter. After fuel I taxied out for a run up, right mag off-normal drop, left mag off-engine quit. Turned the left back on real quick and it kept running. Mixture was leaned when I was taxiing and the DA was about 3,500” after troubleshooting back on the ramp, I could start on the left mag which has the impulse coupling but not the right mag. Pulled p lead off the right mag and started engine with no changes, after doing everything could think of I was about to close it up and try to get a right mag. It had been in the shade for about 4 hours and I decided to swap p-leads from the mags and do a run up. This time everything worked just great, having made the decision to stay the night already I swapped the the leads back and started the engine, no problems. Came out today loaded up and to problems on run up. Took off and flew 3 hours to a field outside Tucson, after landing I checked the mags and problem returned. I’m stuck in Arizona thinking I need a new mag. Does anyone have anything other to check not isolation procedures or advice? It is a Slick 4370 for reference. Thanks
