My 2018 season
aftCG
Tacoma, WA
I beat up the pattern the other day in the evening. One of those times where it makes you smile to have the only key to the hangar.
Anyway, I wanted to try out my two new Flight Flix (I previously said Nflightcam, who also makes nice gear) GoPro mounts. I had to get a skeleton case so I could plug the audio into my intercom.
My goal was to land on the numbers every time.
I thought I should show my mounts in case anyone is interested in filming their own flights.
These are the Flight Flix mounts, with the Vibe-X isolators. The Vibe-X reduces shake and the "jelly" effect that occurs when the frequency of vibration is near a multiple of the 30 fps frame rate.
I could (have/will continue) to make my own hard mounts but these are handy and very well made (overkill actually). The expensive part is the Vibe-X piece, and my attempts to knock off my own version were not as good.
Before clamping anything to fuselage tubes I wrap the steel with silicone "rescue tape". This location only gets an "okay" from me. It's definitely useful footage of cockpit activity but doesn't give a good view outside or of instrumentation. If you put anything inside the plane make sure to assess it for how it might impact humans in an unintentional landing.
The chord you see is my Nflightcam cable for recording audio from the intercom. You can also see the prop filter on this housing which eliminates the strobe effect of the propeller blades. The down side is a slightly less crisp image
That "prop filter" is probably a light blocking filter which slows down the exposure rate of the GoPro so the prop blades won't be caught in individual frames. The prop blades are still there but as a blur through most frames so you are sacrificing image quality to have the blades blurred out.
or maybe you already knew that. :unsure::unsure::unsure:
I've read the description of how it works but it was all a dog whistle. "Blah, blah and then a miracle occurs"
I waisted much of Father's day trying to figure out why the tower couldn't get my transmissions. I thought for sure my Narco mk 12d had died (it's what they do best apparently). I checked all the coax connectors from the antenna to the box, and pulled the plate with the headphone jacks looking for a bad wire. I cleaned and scrapped a few grounds and cleaned the voice out jack with a wire bore brush.
Crystal clear now. After all that I got a short flight with my middle son
I put one of the GoPro stickies on the bottom of the electrical panel. It gets an awesome view out front, side, wheel, and even most of the instruments. It’s an awesome training spot as you see all your mistakes!
Wow that is a great picture, thanks for sharing
Love the photos/video, keep 'em coming! We'll leave it as a miracle, that way we all get a little of it. :)
I went to an annual fly in event at Curtis, WA today. They stress that it's a one way strip - land to the north and takeoff south. They serve up burgers and dogs, have a live band and some conversations about airplanes.
I took more video which will follow.
Going to another fly-in tomorrow. I've heard they have a spot landing contest.
A few non-Citabria images and videos from this season.
This one was from Warbirds Over the West in Salem Oregon last month
The video is my flight from KOLM (Olympia, WA) and back. I was able to see the SDB Dauntless fly (never seen one in real life before) and a very nice P-40 (don't see one of those every day either). The 1946 Swift was my favorite GA plane by a ways, and yes that PT-22 is flawless.
This next one was weekend before last at Skagit Bayview. There was an Aviation Day at this airport just after the 4th of July and I was warmly welcomed by Heritiage Flight Museum for having brought the BT-13, and invited back to the recent event.
What follows is just some scrounged phone footage because it's all I could put together at the end of the day. The Douglas Skyraider dwarfs the BT-13, which is quite large compared to a Citabria. My youngest son made this trip with me after I raved about watching the Skyraider fly. To say it is impressive is a massive understatement. Anyway, immediately after the Skyraider shut down we fired up the BT and Greg Anders followed us out in a T-6. We did two laps of the pattern with a proper FOD check both times and Greg was close enough you could have seen if he had stuff in his teeth. Sadly, the gopro I gave my kid and said "push this button, film anything interesting" - and boy was there plenty to film - didn't have an SD card.
I'm planning on Hood River, OR on September 8-9, and I have been invited back to HFM on Sep 15 for a Red Tail Hawks (Tuskegee Airmen scholarship fund). I'm planning on having less camera malfunctions for those events.
After that we'll put the BT to bed for the winter and I'll have to rough it with my Citabria until spring.
I did go up in the pattern yesterday when it was pretty lousy flying conditions, just because I had the time and was in my hangar. Had some windshear and got tossed around pretty good. Called it quit after 6 t/g in 0.7 on the Hobbs. Two lousy 3 pointers, two wheel landings and two not too bad 3 pointers to close it out.
Well my 2019 air show/ fly in season has kicked off. We sold the BT-13 I was flying for the past few years and bought an SNJ-5.
More on that eventually but here are a few Citabria relevant pics from a repeat of the yearly Curtis fly in.
I was the 42nd plane on the ground, probably twice the number of planes as last year
Here are a few images of the T-6. Unlike most war birds the paint it wears is not only authentic, it's the same livery worn by this airplane in 1952.
My first event in this plane is this coming weekend in Lewiston, ID
Attending the event will be five P-40s, all variants of P-51 (first time in history they'll all fly together), F6-F Hellcat, P-47, B-25. I'm forgetting some but of course also T-28s, T-6s and Stearmans.
I fear the T-6 will be like showing up with a Cherokee 140 but I'm going anyway.
Great Photo!!! I love the reversed horizon and sky shot!!
Thanks for posting!
I was wondering the last few months where the T-6 came from, how did I miss this thread???
Years ago an old timer in a T-6 almost t-boned me as I was entering a traffic pattern and he was leaving the area. If you've ever wondered what a T-6 looks like coming straight at you, well, maybe you're better off not knowing!!! lol
AftCG
Do you operate the Texan as an airshow plane or as a personal plane? Do airshows and fly-ins provide compensation when you show up? Is it enough over the course of a season to cover costs if you're careful about it?
Just curious, never really thought about it before but you got me thinking. :)
Very nice airplane and wonderful for you that get to go flying in it!
AftCG
Bart,
Good question. Back when my uncle flew Warbirds it was expected that air shows would "comp" fuel, a car, food and possibly a room. That dried up decades ago unless you were a big name act.
Once I got used to flying the BT-13 I made it to a couple of fly ins and the plane was a big hit. I spent three years bringing the plane to various events and putting it on static display, all at my own expense. I thought that is just how it was.
Then I started getting invited back to some of the places I've been, a few of which are a couple of air hours from home. At one point I promoted going to an event to a local Warbird group and the first thing they asked was "what are the comps?"
When I asked the group promoter he told me that the event was small and that they hoped to be able to provide something, but not this year.
Then as the event approached he contacted me and said they would buy my gas and two nights in an air BnB.
One day I was on my way to a fly-in but heard of a community Aviation Day that was along my route. I landed and parked next to an A-1 Skyraider and P-51. I never left. I was welcomed warmly by event staff and asked if I would consider flying in the show. What's the right answer for that?
A BT-13 is extremely rare compared to a T-6, with 20-50 left world wide and under 30 flying. They were showcasing Cornelia Fort, the first American pilot shot at on December 7, 1941 while she instructed in an Interstate Cadet. (The movie Pearl Harbor showed it as a dude in a Stearman).
They have the plane she was flying, fresh out of restoration. I didn't know the story, nor did I know that Cornelia snuck back into the history books in 1942 by being the first woman to die in service of her country in the war. She had been delivering at BT-13 to Texas and crashed during formation work.
The act involved Cadet taking off and getting attacked by a "Zero" (modified T-6). After the Cadet landed I buzzed through in the BT. Simple, and a lot of fun.
I make it to as many of their (Heritage Flight Museum) events as possible. I have been asked to fly and on one occasion I flew a couple of hot passes in the BT while Greg Anders flew a T-6 on my wing. I don't know that I have ever had more fun doing anything involving clothes.
Well we sold the BT to a nice guy in Texas and I flew down there with him (14 hours). No sooner had we acquired the T-6 when I got invitations to bring it to events.
The event promoter for the Lewiston, ID show didn't even blink when I asked about gas money and he came through with it. I probably only had two hours in it when I landed so I was only interested in static display. I still put down a 200 mph pass when I left.
Sadly a bad radio, along with a guy who was supposed to buy the plane (but didn't), kept me from flying it much this year. I made it to two events after Lewiston. I flew a veteran at one of them.
Flown sparingly, I could operate it without too bad of a wallet fire. Oil is in gallons and the fuel lines are like garden hoses.
The Citabria is dirt cheap to operate by comparison and I can get it in/out of the hangar by myself with a simple Cessna style towbar. The big tail draggers are 3000lbs and you need a tug and a P-51 style tow bar.
Next spring the T-6 will go back on the block and if/when sold will be replaced with a T-28. For that I need what amounts to a type rating. Fuel burn will be closer to 50gph but thankfully with a 220 knot cruise. Beating up the pattern will be heinously expensive and pulling it off may spell the end of owning the Citabria without a partner or two.
I'm pretty sure I've posted the above before
The Skyraider makes the BT look like a toy
