I think the reason you don't hear damage reports is that Decathlon owners learn to do 3 point, but not full stall, landings. It only takes one full stall landing in that bird to convince you you ought not do that. One really hard landing doesn't usually break a Decathlon, but you will note they have gone to NAS bolts in there - 167,000 psi bolts!
I genuinely curious, why three point if it's not full stall, and what happens after the touchdown?
As you know, in a full stall landing, the aircraft is at the critical AoA when the aircraft lands, the gear compresses a bit, and/or the main wheels drop a few inches to the runway. Both lower the AoA below the critical AoA so that the aircraft is done flying, and you've got the tailwheel on the ground where it starts to have an increasing amount of weight on it, particularly as you're also holding full aft stick, where it starts to add both drag and directional stability. Short of a significant increase in IAS (i.e. a big wind gust) that is sufficient for the aircraft to fly at that lower AoA, the aircraft will continue to be done flying.
Similarly, in a wheel landing the AoA is reduced by relaxing back pressure/adding forward stick, which has the same effect of ensuring the aircraft is done flying. In fact, in gusty wind conditions, the AoA is significantly reduced to ensure the aircraft stays on the ground even if it experiences a 10-20 kt gust. You still have to navigate through the range where a combination of AoA and a gust induced increase in IAS could still lift the aircraft off - while keeping the aircraft straight on the runway with decreasing rudder effectiveness. However with the ailerons against the stops, by the time you start to lose rudder effectiveness, you're slow enough that you can firmly lower the tail and apply full aft stick and effective yaw control from the tailwheel.
However, a three point landing above stall speed is just that, and lacks the AoA reduction qualities of a full stall landing or a wheel landing. You are effectively still flying in close formation with the runway until you lose sufficient airspeed so that the aircraft can't lift off at the AoA it has in a 3 point attitude. Absent any control inputs, a gust in that condition will lift you off the runway. Consequently, I wondering what you do right after you touch down:
- Does the stick go forward to reduce AoA (a tail low wheel landing);
- do you wait for it to slow below the stall speed at that AoA before adding aft stick to put weight on the tailwheel;
- do you apply a judicious combination of brakes and back pressure to get below that critical airspeed quickly (similar to what can be done in a short field situation with a wheel landing, where you want to put weight on the wheels to get maximum permissible braking without nosing over, as soon as possible); and
- when do you decide that the juice isn't worth the squeeze and just do a wheel landing?
