I've been struggling with oil temperatures on my 7ECA, hoping you folks might have some advice.
Today was 95 degrees, which is admittedly warm, but my cylinder head temperatures weren't out of hand, right around 330 in cruise @ 2300 RPM. Oil temperatures still climbed to redline and I had to pull power back to around 2000-2100 RPM to get the temperatures to start dropping, and even then it wasn't significant.
I did an oil change after I landed, since the oil already had 40 hours on it and I figured having just run so hot it might be wise.
I then decided to fly again after the oil change, now 80-85 degrees, and again in cruise oil temperatures steadily climbed to 235 before I opted to head back and call it a day. Total time in climb and cruise power was maybe 15-20 minutes.
We tested the oil gauge with hot water, seems accurate, so I don't think it's a bad gauge. My aircraft has a Casper Labs oil filter adapter on it, which is where my oil temperature probe screws in. Any chance that might cause errant readings?
At annual, one of my mags was overhauled and both were retimed. Is it possible the previous owner has the timing intentionally retarded to manage temperatures? I don't recall having issues this severe last year.
Or is this normal for O-235's and I'm chasing a ghost?
