kubark42
When pushing the rudder, my 1998 7ECA can have a bit of play where the tailwheel steering horn enters into the rudder leading edge tube. It's not loose per se, but it doesn't take a tremendous amount of pressure to get it to snap back and forth between the two positions. This will certainly be happening every time I apply enough rudder to break the caster loose.
(Be sure to turn on the sound to hear the click/thunk.)
Every now and then I had a bit of shimmy when I was learning to fly the plane, but-- likely due to improved control on my part-- it hasn't happened again.
- Is this play a likely source of the shimmy?
- Does it need to be addressed?
- If so, is that as easy as tightening the bolts or removing the control arm and adding tight-fitting bushings?
