Hi all,
Rainbow uses an epoxy varnish product from Poly Fiber called EV-400 to seal wood parts like formers and floor boards. The formers kit I got from Ron didn't have the spruce reinforcing strips on the second and third formers like the factory formers would have. Ron said he's never found the need for them and, with new fabric/paint systems having much less of a tendency over time to really shrink and squeeze things underneath, it's entirely possible that the strips aren't needed. I added them anyway because I can be anal like that.
T-88 epoxy was recommended by Ron for adding the strips but now the new parts have to be sealed up before they can go back in.
As it ends up, brushing EV-400 on works well for the first coat. The second coat activates the first coat so they combine into each other chemically but I found it very hard to brush out a smooth enough finish, especially in high heat and humidity.
Has anyone here ever sprayed EV-400? What gun would I use? Any tips/tricks to getting a nice finish and can it be done outside in the open or would I have to build a booth?
Thanks in advance!
Thanks in advance!
