- Joined
- Apr 4, 2018
- Messages
- 3,998
I am going to complain to Cerco, but meantime let me run this one by you. You - all of you - are a knowledgable group, and I value your opinions, and especially when they diverge from mine.
Scenario: approaching a tower controlled airport under a class B shelf. Normal callup, ending with the word landing. Tower says "aircraft calling, remain clear, call in ten minutes." OK, I have done this before.
While I was holding, two other aircraft called inbound, wanting pattern work. Both were cleared in, A student was given a takeoff clearance to do pattern work. So after that, I asked for my sequence inbound. Controller said "you do not have a transponder - it is too dangerous. Call me in ten minutes. I told him I was climbing to 3,900 feet. That is 100' above his class Delta. When he figured out what I was doing, he gave me a landing clearance.
I think he knew I was going to circle above his tower until I could claim "minimum fuel," and I suspect it was easier to let me land.
So your opinions: I am only required to have 30 minutes of fuel in reserve. I was held for 20 minutes. A departing aircraft was given priority over my landing. The Controller's handbook (now a 729 page monstrosity) clearly states that priority is "first come, first serve." (Exceptions can be found in paragraph 2-1-4, page 48.)
Should I be upset, or should I accept that controllers do not like Cubs, and that I am now an anachronism?
Anything else I should mention to Cerco?
