Cowboys Air Ranch 84ME
My 72 Citabria 7ECA has a Icom A-200 Com, and it works great as long as your withing 3-5 miles of airport or other aircraft. When a greater distance is made, it either has no reception of a transmission, or the received transmission is so much static, it can not be heard or understood. Outgoing transmission is the same problem.
I tried pulling the squelch on all the time, but no different. Tried turning off the intercom, and tried different headphones as well. No luck! Now I replaced the Icom unit with a known good unit and exact same problem.
I'm located in northern Maine, and radio shop will not even look at it (Guess I need to install a glass panel) for them to consider any work. Other radio shop in Maine closed all together. Any ideas on what to troubleshoot or how to go about it? Thinking antenna cable/antenna or both? Antenna mounted on right wing root just above door.
This should be a pretty simple and straight forward operation. Just an intercom attached, NO Audio Panel, or multiple radios. Antenna connectors look good w/o any corrosion, also the tray connectors look good. I hate to throw parts at it, but replacing antenna first may be option, then cable if the antenna swap does not work. I am sure it will be something simple, at least I am hoping it is.
Any Suggestions, Advice, Help????
