Rans S21 - Performance Numbers?
Explorer
Pacific NW
Has anyone compared the performance numbers of the S21 to the Super Cub?
I popped into to see a fellow who's 2/3rds the way thru his build using an IO 340 -180 Hp. With the wing design will it produce similar numbers to the Super Cub?
the S21 in this review has the 180 hp engine option so the article should have the info you are looking for. I googled it because I had never heard of it. looks like a lot of fun.
Thx!
In terms of wing area the Super Cub definitely has more wing. There wouldn't be anyone who out there that has flown both?
Piper PA-18 Super Cub
  • Length: 22 feet 7 inches.
  • Wingspan: 35 feet 2 1/2 inches.
  • Height: 6 Feet 8 1/2 inches (on wheels, not floats)
  • Wing Area: 178.5 feet.
  • Airfoil: USA 35B.
  • Aspect Ratio: 7:1.
  • Empty Weight: 930 pounds (on wheels, not floats)
  • Maximum Takeoff Weight: 1,760 pounds on floats (with gross weight increase kit up to 2,100 lb)
S-21 Outbound Specifications
Rotax 912 ULSTitan XIO-340
Engine power/rpm100 hp@ 5800 rpm180 hp @ 2700 rpm
Gross weight1320 lb1320 or 1800 lb
Wing loading9.36 lbs/sq ft12.77 lbs/sq ft
Empty weight820 lb985 lb
Useful load500 lb815 lb
Wingspan28 ft28 ft
Wing area141 sq ft141 sq ft
Length22.41 ft22.41 ft
Cabin width46.5 in46.5 in
Baggage24 cubic ft/80 lb24 cubic ft/120 lb
Fuel43.5 gal/261 lb43.5 gal/261 lb or 45 gal w/optional larger header tank.
When gross weight is limited to the Light Sport maximum of 1320 pounds, the Titan version of the S-21 effectively becomes a single-place airplane.
S-21 Outbound Performance
Cruise speed 75% power104 kt135 kt
Rate of climb850 ft/min1500 ft/min
Landing roll325 ft375 ft
Takeoff roll325 ft380 ft
Service ceiling12,500 ft14,000 ft
Stall speed clean40 kt43 kt
Stall speed with flaps33 kt35 kt
With 180 hp, the Titan XIO-340 offers much better performance than the 100-hp Rotax 912 ULS, but it’s also more expensive.
I thought the same thing Bartman. In fact, so much that I just ordered a kit. I had the opportunity to visit the factory this week for a grand tour and demo flight. Obviously, I was very impressed.
well make sure you post a build thread here for our peeps to follow. i'll be curious to see how it all goes together.
