I could see maybe if you had a problem with metal in the engine oil
This. Engine is making metal. A pinch of very fine iron filings in last several oil changes. This is not a surprise given the history of the engine. I expected to get a few hundred hours before the lifters spalled and the cam lobes started wearing, which is exactly what I got.
My A&P/IA was surprised by the quantity of the most recent change last week. This is the first time I have carefully measured quantity by rinsing the screen in mineral spirits and then straining through a coffee filter. But he did not go so far as to ground the plane, just saying we needed to investigate and that I should start planning for an overhaul soon. I was already there.
I showed the Zephyr guy the metal and he said yep, gonna need an overhaul soon, but it won't fall out of the sky or anything, it will just gradually lose power and climb rate.
I showed the JB Engines guy the metal and he put the fear of God in me. He said that a spalled lifter could lose a chunk from the edge, which would trash the case. He also said that the iron filings would score the crankshaft so it could not be reground, costing me $7K for a new crank. He said I should have my mechanic pull the left rear cylinder and look at the cam lobes before flying it again.
My inclination is to ground the aircraft now, pull off the engine this weekend, and take it to JB next week. That gets it in the queue at his shop, with a good chance of having it back for the fall acro season.
OTOH there are only 3 contests within reasonable flying distance, and one of them is 2 weeks from now in Rome, Georgia. Right now I am flying well, so I think I would have a good chance of placing. I was toying with the idea of trying to make the Rome contest before pulling the engine. But that would involve 6 hours of XC and an hour or two of acro.
Sooooo ... I was researching ways to better quantify how much risk I am at for trashing the engine. Found some sources that suggested inspecting the prop governor screen. If there is metal at the governor, then metal has reached the crank and I should ground the aircraft immediately. If not, then maybe it won't get much worse in 6 hours.
Right now I'm 99% decided to ground the aircraft today and get the overhaul started. But the Sebring trophies sucked, and the Rome trophies look really nice!
