Phil… if I were doing a cargo run to cabin… I can remove rear seat and stick with only me in the plane per reg. correct?Sorry, too vague. Just thinking if you get somewhere and then want to have a passenger after dumping your gear.
Perfect, thank you Phil.Haven’t checked in for awhile. RIP Robert Szego. The factory has ”quick release pins” for both rear seat and stick. Depending on the fit, there may be some fiddling to get the seat pins in and out. I think they also have a cover for the rear stick hole. I’ve decided unless you have a bulky odd load it works fine for both loading and cg to pack things on and around the rear seat, especially with the rear stick removed…one reason I like the narrow rear seat, and it’s slightly lighter than the wide seat.
Did you find quick release pins?What pins are used for quick release of rear seat? Mine are currently bolted in.
Yes, remove the stick. It may have a quick disconnect for the PTT. If not you will have to install one. Rear seat attachment bolts can also be setup for quick removal. A cover is available from ACA for the rear stick opening.
