I made my own rotisserie after looking at lots of photos and making my own drawings. It had to have certain features, simple to make, not many different sizes of tubing, and it hadto break down and fit in the trunk of my car after building it at my brothers place.
I'm sure someone with better metal working skills and tools could build something better. I just guessed where to put the front pivot point so it would be centered on the rotating CG.
It has simple pivot points front and aft which allow for raising and lowering each end. I have 4 points to lock it in after rotating it every 90 degrees.
I can raise and lower each end with drilled holes in the vertical pieces making it adjustable, the same with the width of the stands on each end. I have 2 long pieces and a short coupler along the bottom to keep the ends from torquing the airframe when moving it around.
I can just rotate it alone if necessary, two is better but there's never anyone around near my hangar to help.
