HalfTonChamp
- Joined
- May 16, 2018
- Messages
- 52
I have always wanted a split door (available) for all champion airframes. Anyone else? Arent they all about if not exactly the same dimensions?
Found a bottom half
https://www.2040-parts.com/split-photo-door-citabria-and-american-champion-i1913909/
I wouldn't be surprised if it fit but you'll have to check the TCDS to see if it was ever an option on your Champ. If not, you couldn't just swap it out without getting FAA approval somehow.
I'm pretty sure the TCDS located HERE will cover it.
I dont believe it was ever an option or on the tcds. But. I thought it should be and since (some) Scouts had them, it could be. (And maybe can beFound a bottom half
I think there is an STC to fly without the door. That sounds cheaper and probably better. The slipstream corkscrew hits the left side, so the increase in breeze is negligible, compared to just the window missing.
In trying to improve on the cub, the designer may have been averse to including anything similar, even if it were the best idea. To wit-a similarly split door. Part of the selling point if youre cub competition is a nice fitting air tight winter door. At the time it was an improvement but since the development of the two-piece Scout door, it would have made sense (to me) to have as an option for all Champion designs. My two cents.I hooked up a little tube to the wing root inlet, taped an airlier-style eyeball vent to it, and aimed it at my nose. Now I make it to eight aileron rolls instead of six before nausea sets in. For door open, nothing beats a Cub. Too bad Champ didn't copy the clamshell.
As to just opening the window, what about a sliding window in the door, like the left window in a Super Cub? Probably fit in the "minor mod" category, and would be much more functional for a photoshoot.
