Sight Gauges
Big Ed
N50247 - '79 Super D
Tampa, FL
My old Decathlon CS had an aerobatic sighting device, but my current Super D does not. I've started to practice the 2021 Sportsman figures and it is very clear I am going to need one. Quickly setting an accurate 45 line on a Cuban 8 is particularly challenging without a gauge. Likewise for verticals, which are closely watched by judges.
Greg Koontz advertises sight gauges for $595. Not too expensive as aircraft parts go, but also seems excessive for what it is.
Anyone aware of any alternatives out there?
I read in an article somewhere that Patty Wagstaff used electrical tape on her window. That would probably work fine for setting angles. Might not be precise enough for leveling wings during vertical lines. Perhaps tape on the underside of the wing for that?
DanO
KBLM
I went with the Greg Koontz option. It’s what Patty W. has on their Super D. It’s expensive but well-designed and engineered. And, I agree it is an particularly helpful for acro in the Super D.
Big Ed
Tampa, FL
Can you share a photo?
Probably gonna buy a chute from Greg in near future anyways.
DanO
KBLM
No adjustments. It is made to fit this very specific spot on the struts. Very well made. I'll take some closeups of it this afternoon when I at my hanger and I'll poet those these evening. Actually I was very pleasntly surprised when I got it to find how well it was designed and made.
Big Ed
Tampa, FL
Thanks, will look forward to seeing pics.
A bit surprised at no adjustment. Would think the middle fixture would need to slide forward and back on the horizontal member, in order to precisely align the vertical member with the pilot's seating position.
I have never judged, but I have been told that judges can see as little as a degree of yaw on a vertical line. Bart?
Unlikely. A macinist may be able to see such minor deviations on a work piece, but aero is dynamic. Things sre always moving. Maybe 3 or 4 degrees, but not one.
Hiperbiper
Shreveport Louisiana DTN
Always used fine line painting tape on the windows...🙃
It's only a reference, no one on the ground can tell 5-10* viewing parallax with any regularity.
This is sometimes the problem when judges are watching different airplanes preform the same routine; an Extra can do a pure vertical roll due to it's build. The same vertical line in a high wing airplane will look off vertical due to the high wing. Throw in a high wing airplane with a flat bottom wing and dihedral and what seems in the cockpit to be vertical will look like the plane going on it's back (over) from the ground.
See if the tape works for you...if not, consider $600.00 out of your wallet will definitely lighten the airframe and improve performance...😊
Big Ed
Tampa, FL
Great pics, thanks for posting! Looks like a very nice device.
What kind of fasteners are the 8 indents on the center piece? Some kind of rivet? Is the other side the same, or some kind of allen screw?
Big Ed
Tampa, FL
That's where ground coaching to calibrate the device comes in. Keep flying verticals and adjusting the device until the coach says you look dead vertical from the judges POV.
Not that I have a coach, or probably ever will. But if I did, that's the kind of stuff I imagine he might do. :unsure:
I am going to try the tape on the windows. I suspect that will work great for 45's and pitch adjustment in vertical. From reading comments by others, I think perhaps the precision of that method may be insufficient to detect yaw in vertical. I might try a strip of duct tape on the underside of the wingtip for that.
DanO
KBLM
Allen screws. Actually, all Allen screws, in two sizes, small and smaller!
Big Ed
Tampa, FL
Hmmm, so if you loosened the allen screws, could you slide the center piece along the horizontal rod? Or do all the rods terminate in the center?
DanO
KBLM
All terminate in the center. It comes assembled (with “top” and “front” labeled), save for the fore and aft pieces (the bullet looking things) that attach to the strut supports and they are each milled specifically for fore or aft.
Big Ed
Tampa, FL
Hmmm. Too bad they didn't drill the horizontal hole thru and use a single rod. Then you could loosen those two Allen screws and slide the assembly fore and aft to fine tune wings level on vertical lines.
Hiperbiper
There has to be some fore/aft adjustment with the sight. I'd bet if both grub screws were loose the center of the star will shift back and forth. Otherwise it would only work for one sized pilot...
I remember many moons ago someone had a cool sighting device in a Decathlon; .060 clear plastic with the lines drawn on it. It was attached to the windows (one each side) using small suction cups...
Simple, adjustable and removable.
Today Velcro would work better than suction cups...
Might be something to play with...
DanO
KBLM
I‘m sure that GK Airshows could answer the question and provide insight. Above my pay grade.
Big Ed
Tampa, FL
I plan to visit GK to buy a chute at some point this summer or fall ... unless I stumble across a used seat chute for sale.
Big Ed
Tampa, FL
Following up ... I spoke to Greg at Oshkosh and he showed me how the gauge works. It is adjustable. The rods slide in and out of the mounting brackets with the Allen keys loosened, allowing the web to be moved fore and aft to adjust yaw. The mounting brackets also move up and down separately to change pitch and roll.
Also of note, the factory produces and sells a gauge for the same price. They appear to be similar in design and construction.
Right now both are out of stock, like everything in the world.
If really interested in competition, a sight gauge is indispensable, IMO.
