In moving my project along I'm trying to get the details of the new panel figured out. Some of the pieces for the panel such as the Garmin USB ports and the AV-30 attitude indicator have circuit breaker requirements in their installation manuals. Others don't.
So, in going to AC 43-13 , the circuit breaker sizing guidance says;
The Garmin GTX 345 Comm lists the electrical power requirements but doesn't specifically list the circuit breaker that should protect the unit. Here's the power table and the area I think I will need to follow is highlighted.
So there needs to be a CB for this device but what should the CB be rated for? Less than the 14V max current of 1.43 or the next larger breaker of 1.5A or something else? This is assuming the wire won't be the limiting factor determining what the breaker should be.
Circuit protection devices must be sized to supply open circuit capability. A circuit breaker must be rated so that it will open before the current rating of the wire attached to it is exceeded, or before the cumulative rating of all loads connected to it are exceeded, whichever is lowest. A circuit breaker must always open before any component downstream can overheat and generate smoke or fire. Wires must be sized to carry continuous current in excess of the circuit protective device rating, including its time-current characteristics, and to avoid excessive voltage drop. Refer to section 5 for wire rating methods.
