Cowboys Air Ranch 84ME
Howdy,....
I have a 1C90CLM7246 Propeller on my 72 Citabria 7ECA w/ Lyc O-235-C1. Static is only 2225 RPM (Measured w/ Strobe Tachometer), and level flight 2600 RPM, which matches to dash tachometer. Performs OK, but looking for a little better climb.
I did some research, and found that Buzz Wagner Conversions state that repitching down to 42 inchs should give me the 2425 Static RPM's which is in the top range for this aircraft (2225 to 2425 static range as per ACA). Should give me 2800 RPM full throttle in level flight.
So, I operate 99% of the time from grass runway, and speed is NOT a factor, but performance is. I level out at 3000'MSL, and lean and get 115 MPH (100 KTS) True airspeed now.
Question #1, If I were to put on a finer 42 inch propeller pitch, what would my speed be?
Question #2, How much fuel would I burn cruising at 2800 RPM (My Operators Manual says 2800 RPM constant). Manuals for later years say 2600 RPM constant, and 2800 RPM max.
Question #3, Anyone have a propeller of the 42 pitch I can borrow and try, or one for sale, or know of anyone who does,
Lastly, I Love this airplane, and I will be buying a performance Citabria w/ 150hp or larger engine in a few years (Just not right now). This is only a "Stepping Stone" Citabria for me.
Comments? Input? Anyone flying this pitch?
Ken "COWBOY" Winiarski
84ME Cowboys Air Ranch
