I may be wrong but I believe that there are single and double power supplies. If you have one power supply that powers two strobe fixtures then it's a double. My Citabria had single supplies and they were each mounted to the side of the second to last rib in each wing. There was a large aluminum panel crafted into the fabric under the tip where you could access them.
There are going to be a lot of perfectly good used units as LEDs continue to replace the filament style lights so prices should be coming down. I gave my light fixtures and power supplies away to a person that helped with the project.
