- Joined
- Apr 4, 2018
- Messages
- 4,180
First, happy that Ed was not seriously affected by Ian - best wishes to our Florida buddies.
So this nice 160 Citabria has had tailwheel problems. I fixed it a couple years ago - wedges, tighten the tension - worked fine. It was a club airplane, and has had a hard life.
A really nice guy now owns it. I borrowed it today to move some parts around, and noticed a horrible shimmy - I mean BAD.
Since I last worked on it it got a new Bushwheel, and a new spring, and compression-type rudder springs. Those new parts are what is shimmying.
I know about the kingpin angle, and have experience rebuilding the Scott 3200, which is apparently the same as the Bushwheel. I have heard rumors that there is a Bushwheel part that dies fairly rapidly in there, but am not sure it has anything to do with shimmy.
So when I got back, I suggested three things: 1- bring tire pressure up to 50-60 psi. 2- tighten the friction nut, and 3 - if that doesn't do it get rid of that big expensive tire and replace it with the proper 2:50/2:80x whatever - Carlisle makes them.
The angle appears ok.
Can anyone think of anything else we can check? This is otherwise a gorgeous aircraft, and has had tailwheel issues for at least the last decade. It is a 3003, I think - GCAA.
