I would not use chemical stripper, it'll cause more problems than you're trying to solve. I'd recommend mechanical removal.
If you brought it to my shop, I would wire brush those spots in the door area to remove loose primer and corrosion, scuff the primer that stays, clean with alcohol or paint prep and spray it.
The longerons may need more aggressiveness. I would peel back the fabric, and use a wire wheel to remove the corrosion. May need a hand wire brush for the tight spots. You could carefully use a portable sand blaster, but it makes a big mess, so I wouldn't. Scuff, clean and spray the tubes. Then the fabric work to get the belly back on.
Leave the good primer in place.
